MRP oval ring: 30t Cinch
mack_turtle
I used this a few times for singlespeed but the oval has a loose-tight pattern that does not work well. Should work fine with a derailleur. For RaceFace direct mount. Has an offset but not sure what chainline will result on your cranks.
(Oval rings should work fine on a singlespeed without a tight spot. Also does not look oval because of the photo angle.)
15 bucks or bring me six-pack of something stout and strong.
  • 2 weeks later...
