AustinBike Posted May 24, 2021 Share Posted May 24, 2021 Looks like we will be spending a month in Santa Fe if everything works out and I am trying to figure out which bike to bring. My hardtail has crappy SRAM brakes and I need to pick up some Shimanos so that I can ride some real trails. If anyone is doing an upgrade and wants to sell me their old Shimano, let me know. Otherwise I'll just put in an order online, looks like SLX's are about $225 from the UK. Quote Link to comment Share on other sites More sharing options...
mack_turtle Posted May 24, 2021 Share Posted May 24, 2021 I was having endless trouble with my older SLX brakes, so I moved to TRP Slate 4 brakes. they're terrific so far. the pads are the same shape as some of Shimano's 4-piston brakes, so replacement pads are easy to find. you can bleed them with the Shimano bleed funnel too. not sure if the price is similar, but if you can find a deal on TRP brakes, I'd give them a try. SRAM brakes suck. 1 Quote Link to comment Share on other sites More sharing options...
ATXZJ Posted May 24, 2021 Share Posted May 24, 2021 (edited) Lordgun is one of the last euro retailers that still ship here and occasionally have some really good deal. Had good luck with them in the past https://www.lordgun.com/_bike-components/bike-brakes/_MTB Edited May 24, 2021 by ATXZJ Quote Link to comment Share on other sites More sharing options...
AntonioGG Posted May 24, 2021 Share Posted May 24, 2021 I've ordered a bike and I'm either going to replace the XT brakes with my XTR, or get rid of the XTR brakes. The problem is I don't know when my bike is coming. Hopefully soon. Quote Link to comment Share on other sites More sharing options...
AustinBike Posted May 25, 2021 Author Share Posted May 25, 2021 11 hours ago, mack_turtle said: I was having endless trouble with my older SLX brakes, so I moved to TRP Slate 4 brakes. they're terrific so far. the pads are the same shape as some of Shimano's 4-piston brakes, so replacement pads are easy to find. you can bleed them with the Shimano bleed funnel too. not sure if the price is similar, but if you can find a deal on TRP brakes, I'd give them a try. SRAM brakes suck. The reason I stick with Shimano is because I can bleed them easily and all of my bikes have XT or XTR on them. I'm like Southwest with 737's. Except for that one hard tail. Quote Link to comment Share on other sites More sharing options...
AustinBike Posted May 25, 2021 Author Share Posted May 25, 2021 6 hours ago, AntonioGG said: I've ordered a bike and I'm either going to replace the XT brakes with my XTR, or get rid of the XTR brakes. The problem is I don't know when my bike is coming. Hopefully soon. Based on all this rain you better go check your garage, it may be there already. Quote Link to comment Share on other sites More sharing options...
mack_turtle Posted May 25, 2021 Share Posted May 25, 2021 13 hours ago, AustinBike said: The reason I stick with Shimano is because I can bleed them easily and all of my bikes have XT or XTR on them. I'm like Southwest with 737's. Except for that one hard tail. TRP use the same bleed process. when I got mine, I flushed them out and replaced the oil with Shimano oil because I have a huge bottle of Shimano fluid. one year later, no problems. Quote Link to comment Share on other sites More sharing options...
AustinBike Posted May 25, 2021 Author Share Posted May 25, 2021 Does it use the same diameter cup? Quote Link to comment Share on other sites More sharing options...
mack_turtle Posted May 25, 2021 Share Posted May 25, 2021 16 minutes ago, AustinBike said: Does it use the same diameter cup? my Slate 4 levers fit a Shimano bleed cup just fine. I had Hylex brakes on my gravel bike at one point and the fitting was different. Quote Link to comment Share on other sites More sharing options...
AntonioGG Posted May 25, 2021 Share Posted May 25, 2021 23 minutes ago, mack_turtle said: my Slate 4 levers fit a Shimano bleed cup just fine. I had Hylex brakes on my gravel bike at one point and the fitting was different. There's an adaptor for drop bar levers bleed cup. Interestingly my new gravel bike included the adaptor. Quote Link to comment Share on other sites More sharing options...
