AustinBike Posted September 20, 2022 Share Posted September 20, 2022 I have a 2019 Orbea Occam and the rear shock fits into a mounting directly. I am assuming that this is aluminum because you would not screw a shock into carbon, right? This comes loose after a few rides and the whole back of the bike gets "loud". I re-torque it down to the 6nm spec and it is great for 2-3 rides. Then it starts getting loose again. I did a little research and it looks like people are mixed with some saying that you should not use loctite on anything that you are going to want to remove. What is the collective wisdom here? Quote Link to comment Share on other sites More sharing options...
RedRider3141 Posted September 20, 2022 Share Posted September 20, 2022 There are lots of variety's of Loctite from low strength to high strength. I would NOT recommend High Strength Loctite for your use case. Loctite is like Kleenex and within in the brand it goes like the following: Low Strength PURPLE 222 Removable BLUE 242 High Strength RED 271 Other brands of thread locker may have different colors. Use Cases: I use Purple at work, typically in very light duty steel to plastic joints that are regularly serviced. I use Blue in several locations on my car/motorcycle/bike including rear suspension bolts (when I had a FS). These were all Stainless Steel bolts into Stainless Steel Nuts or Aluminum Castings. I don't have experience using it on composites unless it was into a metal threaded sleeve. I use red on things I don't ever plan on taking apart. The label on Red says "Must be heated to 500°F to separate parts" 6 Quote Link to comment Share on other sites More sharing options...
AustinBike Posted September 21, 2022 Author Share Posted September 21, 2022 Last night at the R&I an engineer and master bike guy both chimed in that the bolt should have Loctite. This morning I removed the bolt and found that my answer was there all along: Cleaned it off and added fresh loctite. 3 Quote Link to comment Share on other sites More sharing options...
