Best solution for locking bike to wall
AustinBike
  • 3 weeks later...
I have two large i-bolts screwed into a stud. The bolt i-ends are just far enough apart that they could be screwed in and a u-lock can fit through. You can't unscrew them with a lock through both at the same time. A determined theif would just cut the lock, but that would take a whle and make a lot of noise.
That is a really good idea. At this point I am not really worried about how durable the lock is, this is about keeping it from being taken quickly because the door was accidentally left open. My assumption is that once someone gets inside the garage and closes the door, they have access to tools. Mostly wanted to stop someone from walking down the street, seeing someone left the door open, and grabbing the bike.
Just need to be sure to also lock up the Ryobi Angle Grinder, if stored nearby. 🤔
