AustinBike
Locktite on a Cassette Ring?
I have been having issues with a cassette that keeps coming loose on my FS bike. Yesterday I had to do several mid-ride adjustments before I could get back to the car where I had a lock ring tool.
Is it advisable to use locktite? The free hub is a Chris King steel (not aluminum) and the cassette is a Sun Race 11T-42T.
I would try it with the purple first since there is alot of contact area the regular strength could be hard to get off later down the road. That being said I did this and had no problems with it other than struggling when it cam to removing it.
The cog retainer on a new to me CK SS hub backed off on a ride last week. That was a first for me. I pulled out the torque wrench and put it back on, but will probably go to blue loctite if it doesn't stay tight.
I've always torqued to the specified level (40Nm iirc) and have never had one back off. You're using a torque wrench? I don't have King's so perhaps there's something with them. Can't trust that Chinese crap.
Loctite makes a lot of products. The light blue 242 product should do it without being dangerously difficult to remove.
However, all lock rings should stay secure when properly tightened. Use a torque wrench. If it still comes loose, there may be something else going on. Is the cassette missing a spacer?
I am going to try the loctite tomorrow. No spacers missing. Need to see if my torque wrench has an adapter to go that large, I have a smaller wrench.
I had that happen once out at WC. I carry a lockring tool on every ride now even though it hasn't happened again since.
+1 on the 242 Blue locktite.
Edited by Teamsloan
Ok newb, come back when you've torqued it to 40Nm. It's more than you think.
Edited by Anita Handle
Thank you.
This. Most cassette lock rings have a knurled interface that should never come bloomed so if it's properly tightened and it comes loose something is wrong.
I have properly torqued a cassette lock ring exactly once, and then never again after it took forever to get off.  Never had one come loose.  Is your lock ring just worn out?
Are you using the Chris King lock Ring? If I’m not mistaken it’s a proprietary item with its own thread pitch different than Shimano/Sunrace
It was a pretty new cassette, less than 6 months old, but a cheap brand (Sun Race).
I'm going to buy two 11 x 42 cassettes so been researching reviews on Sunrace and can't say I've come across this particular problem. But they do have two different models, the CSMS3, which is the cheaper one and has poor reviews about quick wear, and then the CSMX3, which has very good reviews.
Nope, using the one that came with the cassette. Let me dig into that, good to know.
The SS hub has a proprietary design though also works with the standard style lock ring. The normal geared hub works with standard lockrings, though king does sell their own too. My guess is the cassette slid on and you tightened it less than design torque and the cassette and spacers compressed in with time, narrowing the whole assembly. Certainly possible if portions of the cassette are pinned together.
Just reassemble and torque it, it'll be fine.
This has been an ongoing issue. Started last fall. Cranked it down on a road trip. Then again in December. Then January. Now this month. Not a one time occurrence, there is a pattern here.
Actually both Sunrace and Box have some quite decent wide range and well spaced 11 speed options.
