mack_turtle Posted September 27, 2018 Share Posted September 27, 2018 anyone have access to equipment to modify a small aluminum part? Quote Link to comment Share on other sites More sharing options...
notyal Posted September 27, 2018 Share Posted September 27, 2018 Depends on the type of modification you're looking for, but... I might have you covered. 1 Quote Link to comment Share on other sites More sharing options...
Yosmithy Posted September 27, 2018 Share Posted September 27, 2018 If you can post up the part you need done, I can see if it's something I can handle. I have a lathe and a Vertical milling machine, but a limited amount of tooling at this point. Note; I've been called a lot of things, but "machinist" is not one of them 🙂 Quote Link to comment Share on other sites More sharing options...
mack_turtle Posted September 27, 2018 Author Share Posted September 27, 2018 (edited) here's a super high-tech rendering of what I need to do: drill/ tap a third hole in the sliding dropout about 10 mm in from where it is, then remove the additional material from the mounting tab. I need to at least drill and tap that hole with enough precision to get the bolt in straight. I am basically trying to shorten the mounting tab so that I can slide my axle forward enough to remove a link from the chain. (cue long debate about chain stay length. spoiler: I want mine shorter, because.) you can see that the Paragon equivalent (blue background) has a much shorter tab, so it should be fine. my frame has room for 3" tires, and I am running 2.25-2.3's, so there's plenty of room in the frame. if needed, I can shave some material off the axle mounting area to clear the dropout part as well. Edited September 27, 2018 by mack_turtle Quote Link to comment Share on other sites More sharing options...
Yosmithy Posted September 27, 2018 Share Posted September 27, 2018 yeah, I can probably do that. What's the time frame? 1 Quote Link to comment Share on other sites More sharing options...
mack_turtle Posted October 18, 2018 Author Share Posted October 18, 2018 thanks Yosmithy for making this work! of course I can't test this out much because of the rain (or perhaps the rain is because of my desire to test it out), but I now have a frame that was designed with a 17" chainstay length at 16.5". This does not allow me to use a tire much bigger than 29x2.25, but it's at least I can try riding with a low BB and short CSL until I dial it in. I even went out and bought some shiny new stainless bolts for it. 2 Quote Link to comment Share on other sites More sharing options...
