AntonioGG Posted January 23, 2019 Share Posted January 23, 2019 17 hours ago, rockshins said: Extra step if you haven't tried is to adjust the lever reach and free stroke before you start. Have heard every which way, to have the lever reach and free stroke fully open, or to have the lever reach fully open and the free stroke closed and the opposite of that. The best bleed I have gotten is to have the lever reach all the way to the bars (closed) and free stroke all the way open, but who knows. Seems like you can have extra air in those spots. This is not something I had tried. I'm looking forward to trying this out soon. Thanks! Quote Link to comment Share on other sites More sharing options...
Anita Handle Posted January 23, 2019 Share Posted January 23, 2019 have you tried the "mini bleed" method where you only open up the lever end, attach a syringe to the lever with some fluid in it and flick? http://www.epicbleedsolutions.com/blog/5-minute-shimano-mini-bleed/ Magura has a similar process, where the caliper is left alone, but it involves actually drawing a vacuum at the lever end and drilling a small pilot hole in the syringe so that when you draw back to a certain point, you can release the negative pressure. Negative pressure can do wonderful things for getting a bubble to migrate. https://www.magura.com/media/1856/quick_bleed_instruction_final_techtip_2_may_2012_01.pdf Quote Link to comment Share on other sites More sharing options...
AustinBike Posted January 23, 2019 Author Share Posted January 23, 2019 Yeah, I tried the mini-bleed. It worked for a bit. I have a big bottle of oil coming this weekend and I am going to try all of the tricks together. Quote Link to comment Share on other sites More sharing options...
Ridenfool Posted January 23, 2019 Share Posted January 23, 2019 With that much oil in play you may want to invest in rubber sheets too. 1 1 Quote Link to comment Share on other sites More sharing options...
AntonioGG Posted January 28, 2019 Share Posted January 28, 2019 I released all the lever travel to max. I was shocked at how far I had it in. Then I took the caliper off the bike and let it hang right under the lever. So many bubbles came out. I used less than one little cup full of fluid to get it feeling really solid. We'll see if that lasts after some use. Looking forward to seeing how your experience went AB. I figured you're busy editing pictures and such. Quote Link to comment Share on other sites More sharing options...
AntonioGG Posted March 7, 2019 Share Posted March 7, 2019 I'm reporting back after over a month and my rear brake is solid. So the trick was opening up the reach adjust to max when bleeding. 1 Quote Link to comment Share on other sites More sharing options...
AustinBike Posted March 7, 2019 Author Share Posted March 7, 2019 My bleed finally worked, had to do it 2 or 3 times. Bought some additional fluid and now I have enough to do about 100 or so brakes because they only sell it in liters. If anyone ever needs a Shimano bleed, hit me up. Quote Link to comment Share on other sites More sharing options...
