Mattlikesbikes Posted August 30, 2018 Share Posted August 30, 2018 Take off from an intense tracer RockShox rt3 debonair. Label says MMS380 tune. Sag at 30% Photo is of all the travel I used bombing down a 3000 vertical foot down trail in Colorado two weeks ago. Used 95% of the fox 34. Volume spacers? Quote Link to comment Share on other sites More sharing options...
Chief Posted August 30, 2018 Share Posted August 30, 2018 (edited) What is the stroke on that shock? Measure the distance from the can to the ring if it comes up the same as stroke you're good. Edited August 30, 2018 by Chief Quote Link to comment Share on other sites More sharing options...
cxagent Posted August 30, 2018 Share Posted August 30, 2018 The answer is obvious - you don't weigh enough. Says the old fat guy. 1 Quote Link to comment Share on other sites More sharing options...
TheX Posted August 30, 2018 Share Posted August 30, 2018 12 minutes ago, cxagent said: The answer is obvious - you don't weigh enough. Says the old fat guy. It's true. Quote Link to comment Share on other sites More sharing options...
Mattlikesbikes Posted August 31, 2018 Author Share Posted August 31, 2018 2" stroke. I am at about 1.25, so lots to go. 225 with gear, should be heavy enough. Quote Link to comment Share on other sites More sharing options...
Kyle Posted August 31, 2018 Share Posted August 31, 2018 Take the air can off and look inside for anything weird. While you're in there freshen up the oil and remove any volume spacers. 1 Quote Link to comment Share on other sites More sharing options...
Bamwa Posted August 31, 2018 Share Posted August 31, 2018 Looks fine to me if you weren't bottoming out. 1 Quote Link to comment Share on other sites More sharing options...
ATXZJ Posted August 31, 2018 Share Posted August 31, 2018 Dumb question but, do you get full travel with all the air out of the shock? Quote Link to comment Share on other sites More sharing options...
Mattlikesbikes Posted August 31, 2018 Author Share Posted August 31, 2018 (edited) 28 minutes ago, ATXZJ said: Dumb question but, do you get full travel with all the air out of the shock? Yes. Let all the air out and it goes to full travel, 20mm more of stroke. So rough math, 40% left, and 30-35% sag means my operating window is 25-30% of the 50mm. I'll get it into the vice and get the can off see what spacers look like. Should I just pull them all and put back as needed or take some and keep taking more as needed? Edited August 31, 2018 by Mattlikesbikes Quote Link to comment Share on other sites More sharing options...
Kyle Posted August 31, 2018 Share Posted August 31, 2018 I'm not sure about that exact shock, but there's probably just a single spacer. I'd take it out if there is one and see how the bike feels, and then consider adding a smaller one back if you need it. Quote Link to comment Share on other sites More sharing options...
Mattlikesbikes Posted September 1, 2018 Author Share Posted September 1, 2018 No spacers. So, while it should be the right tune (mms) it's a bit much. I guess I experiment with lower pressure/more sag to see what it takes to get 95%. Quote Link to comment Share on other sites More sharing options...
